This is an interesting problem. The boiler is a Worcester 240 Balanced Flue.
Went away for a few days and switched off the power - not the gas.
On return the pilot was out. It would spark up and light whilst holding in the button - up to 2 mins - but always went out as the button reached its outward limit. Checking the obvious, the thermocouple was changed but no result. Next check was the Overheat themostat. With a resistance meter it was found to have a circuit at the gas valve. (Both ends removed from the valve for this check). So thought the OH stat must be good. However, by shorting the two connections on the gas valve the pilot would stay on - albeit not protected should it go into an overheat situation. A new OH stat has been ordered but can anyone throw light onto this strange one.
Why does it work with a piece of wire across the connections but not with the stat that shows closed circuit when tested.
