DIYnot
Local | Network
   DIYnot > Forums
Local | Network
P shaped bath no fitting instructions?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Juggler
from United Kingdom
PostPosted: Sun Jun 29, 2008 9:26 pm Reply with quote
Just bought a bathroom suite with a P shaped bath, but no instructuions on how to fit. There are 10 metal brackets with slight kink in, about 3 inches long and 1 inch wide. Doesn't seem to be any thing to fix them to?
Andy
Back to top
 Alert Moderators
Salmonfisher
from United Kingdom
Thanked: 1 time
PostPosted: Sun Jun 29, 2008 9:46 pm Reply with quote
for holding on the bath panel
Back to top
 Alert Moderators
Juggler
from United Kingdom
PostPosted: Mon Jun 30, 2008 8:14 pm Reply with quote
Hi, these brackets are quite substancial, I think they are supposed to attach the back of the bath to the wall but not sure how?
There are some smaller brackets which I have figured out are to secure the panel at the front but its not very obvious how they fit.
Andy
Back to top
 Alert Moderators
AMEdinburgh
from United Kingdom
Thanked: 4 times
PostPosted: Mon Jun 30, 2008 8:55 pm Reply with quote
I may very well be wrong but these brackets may be designed to screw to the wall or walls bordering the bath screwed in the lower half and the top half out a little from the wall. The bath is then carefully lowered so that the clips slip inside the bath edge nipping the bath against the wall. Remember to strike a truly horizontal line on the walls and check any corners are 90 degrees. Once the bath is hooked over the clips, then set the adjustable feet so its level front to back and you're set.
One of the baths I've fitted for myself in the past had has this sort of arrangement
Back to top
 Alert Moderators
Juggler
from United Kingdom
PostPosted: Tue Jul 01, 2008 6:33 pm Reply with quote
Thanks for the info, I can see now how it will work!
Andy
Back to top
 Alert Moderators
shanetasha
from United Kingdom
PostPosted: Mon Oct 19, 2009 11:54 am Reply with quote
hi the clips are to hold the front bath panel on if you look under the rim of the bath you will see little blocks of wood to fix them to
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Pressurised shower - p shaped bath slowly filling 7 440 Wed Apr 14, 2010 6:06 pm
where do i centre the shower on a p shaped bath? 4 560 Sun Mar 28, 2010 2:33 pm
Can I fit P shaped shower bath? 4 140 Mon Feb 21, 2011 4:48 pm
P shaped bath panels 4 80 Fri Nov 29, 2013 8:37 pm
P Shaped Bath missing batons and panel height 2 60 Sat Jan 22, 2011 11:33 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
