DIYnot
Local | Network
   DIYnot > Forums
Local | Network
how to fix a curtain pole
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
Vaskunito
from United Kingdom
PostPosted: Thu Jul 03, 2008 5:15 pm Reply with quote
Hi people,
i have a basic question and I was wondering if someone can give me a few pointers.
ok I want to fix a metal curtain pole (not that heavy) onto the wall shown in the photo bellow:
Now the problem with this wall, is that above the red line I have drawn, it is impenetrable with any masonary drill bit I tried to use. I can only go so far as 2-2.5 cm deep (not deep enough for the rawlplug to enter) and then I hit somekind of impenetrable surface, which I think might be metal. Not sure. The result is I cannot fix the screws above the red line (point B).
Under the line (point A) there is no problem and I can drill deep enough. However the problem is that this window frame is about 2.30 m long and I might need to fit another supporting pole hook in the middle at point C.
Now, i was wondering. Is there any way to fix the pole at points B and C? And if so how can i do that? keeping in mind I can only penetrate the wall a few centimetres. Have you ever seen a wall like this before? (is it called drywall, hollow wall?) it sounds approximately the same if you tap at A, B or C.
I would appreciate any help as I am currently without curtains icon_redface.gif
Thank you
Back to top
 Alert Moderators
xerxes
from United Kingdom
Thanked: 1 time
PostPosted: Thu Jul 03, 2008 6:22 pm Reply with quote
It seems you are drilling into a lintel, which is either reinforced concrete, or steel.
If a masonry bit stops drilling, try following it with a (good, sharp) HSS twist bit (without hammer) to penetrate the steel.
If it's a steel lintel, it will be hollow behind and you' may need to use a hollow fixing for your curtain pole; it it's steel reinforced concrete, you'll have more concrete to drill once you've penetrated the steel.
Choosing a different position for the holes (above or below the reinforcing rod) would be another option.
Standard masonry bits and impact drills can struggle to penetrate hard materials. An SDS drill with good quality SDS bits will make life much easier.
Back to top
 Alert Moderators
Vaskunito
from United Kingdom
PostPosted: Thu Jul 03, 2008 6:34 pm Reply with quote
yes i see. Thank you for your reply xerxes. I will try a different drill bit to penetrate the metal.
By the way, if I decide to chose a different position, lets say higher, how tall/wide are these metal lintels usually? Would it most probably reach all the way to the ceiling? Thank you
Back to top
 Alert Moderators
xerxes
from United Kingdom
Thanked: 1 time
PostPosted: Thu Jul 03, 2008 6:49 pm Reply with quote
I wasn't entirely clear, I'm sorry.
Choose a higher position to miss a horizontal steel reinforcing rod in a concrete lintel.
If you're drilling into a steel lintel, it shouldn't be difficult to drill into it with the appropriate bit, whatever the position.
You could try asking your neighbours with similar houses (if there are any) if they've had similar problems: this could help you identify what you're dealing with.
Back to top
 Alert Moderators
Vaskunito
from United Kingdom
PostPosted: Thu Jul 03, 2008 7:02 pm Reply with quote
right i got u this time.
so there are two cases as you say 1) concrete lintel with possible reinforcing steel rod
or
2) steel lintel
I dont think I can go any much higher than position B (there is a maximum height I can fix the hook, or else the pole with touch the ceiling skirting) but I can always go lower A (but wont be able to attach a hook in the middle C for reinforcement).
So assuming I cannot avoid the steel (steel rod or steel lintel) an HSS drill bit should do the trick in both cases right? Have I understood that correctly?
Back to top
 Alert Moderators
xerxes
from United Kingdom
Thanked: 1 time
PostPosted: Thu Jul 03, 2008 7:09 pm Reply with quote
That's right. Once you hit steel you need to swap to a metal drilling bit to penetrate that (without hammer action).
Back to top
 Alert Moderators
Vaskunito
from United Kingdom
PostPosted: Thu Jul 03, 2008 7:14 pm Reply with quote
gotcha thanks.
just one last followup question. Assuming i manage to penetrate the steel with the HSS there are two possibilities behind the steel:
a) Hollow wall --> i use a hollow wall fixing th
or
b) concrete --> i use the normal rawlplugs
Right?
Back to top
 Alert Moderators
xerxes
from United Kingdom
Thanked: 1 time
PostPosted: Thu Jul 03, 2008 7:30 pm Reply with quote
That's right.
However, I've no personal experience of fixing to steel lintels. Perhaps somebody else will come along to help with that one.
As I say, it's possible you have neighbours who can tell you what's underneath your plasterwork.
Back to top
 Alert Moderators
Vaskunito
from United Kingdom
PostPosted: Thu Jul 03, 2008 7:33 pm Reply with quote
alright cheers xerxes. at least I have some idea of what might be behind and how to drill through it. much obliged. Thanks again
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Fri Jul 04, 2008 7:56 am Reply with quote
When I hit the steel rod in the concrete lintel, I use a small HSS drill bit then another one for the right size HSS drill bit to take the rawlplug, self-tapping into the steel without rawlplug is very difficult to do because of the thickness of the steel rod.
Back to top
 Alert Moderators
Vaskunito
from United Kingdom
PostPosted: Fri Jul 04, 2008 8:23 am Reply with quote
alright. I am gonna go to my local B&Q today and buy an HSS drill set and try this way.
Thanks guys
Back to top
 Alert Moderators
Vaskunito
from United Kingdom
PostPosted: Sat Jul 05, 2008 5:52 pm Reply with quote
followup:
I bought a set of titanium drill bits and another for concrete and after 1 hour of drilling I manage to do it. 3 perfect holes. Very slow process.
I think there was concrete behind and not metal. Still very very tough to penetrate. Could never have done it with normal brick drill bits.
Back to top
 Alert Moderators
xerxes
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jul 08, 2008 5:58 pm Reply with quote
Well done: good work.
Back to top
 Alert Moderators
Vaskunito
from United Kingdom
PostPosted: Tue Jul 08, 2008 7:17 pm Reply with quote
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Curtain pole frustrations 4 180 Sun Nov 23, 2014 10:48 am
Need help with putting up curtain pole please.. 3 100 Mon Aug 18, 2014 6:21 pm
securing a curtain pole bracket to crumbly lathe wall 2 1020 Tue Oct 13, 2009 10:01 am
Fixing curtain pole 3 80 Sat Oct 13, 2012 8:53 pm
FIxing curtain pole to bad wall 9 2800 Tue Dec 09, 2008 5:03 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
