My inner leaf is loose
10 Apr 2007
Humberside
Hi Guys,
Started building up with the blocks last week but due to weather conditions in GRIMsby i only got 1 coarse either side of the cavity done.
On the outre leaf I put some cement on the engineering bricks to hold the DPC in place then put more on top and put the wall ties in place at 400mm centres.
The inner leaf was just the same with one exception i rolled the DMP over the DPC then cemented the blocks onto that, i used the same barrow of cement for both leafs but unfortunatly the inner leaf is loose while the outer leaf is rigid, what have i done wrong ???
Should i not have rolled the DPM over the DPC and just cut it down so it hides behind the skirting as i will have to relay that coarse on the inner leaf ???
Cheers in advance
Stan.
the connection at dpc, particularly the inner leaf where there are layers of low cohesive materials, is relatively weak.
it will only stiffen or stabilise once weight is added i.e more courses of block.
a single course of block, directly upon the dpc or dpm, could easily be pulled away.
Don't worry about it. When you come to fit the kitchen units, if they don't fit, then you can just knock the wall back a bit :LOL:
