keithrutter
Joined: 05 May 2002 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Sun May 05, 2002 8:45 am Post Subject: Cork tile removal |
I have had to use a bolster chisel and 2lb hammer as well as a scraper to remove tiles laid 20 years ago. I am only removing them as some have been damaged when the dishwasher leaked, the insurance company insisting on replacement with ceramic tiles. |
Guest
Posted: Sat May 11, 2002 11:03 pm Post Subject: Re: Cork tile removal |
Guess there's no easier way then? I've tried to remove some today and ended up with the same tools - plus a hot air stripper and two broken scrapers!
Anyone know if you can use self-levelling compound over broken cork tiles?
David |
Anton
Joined: 01 Feb 2002 Posts: 82 Location: Manchester, United Kingdom Thanked: 0 times
Posted: Tue May 14, 2002 1:04 pm Post Subject: Re: Cork tile removal |
Is that Keith Rutter of Jersey/ex M/C? Surely there can't be another one! |
Guest
Posted: Wed May 15, 2002 3:03 pm Post Subject: Re: Cork tile removal |
No, I am not the Keith Rutter in New Jersey, I am the keith Rutter in Wales, UK, but the tiles stick just as well over here. A sharp scraper was the only thing that had any effect. I tried wire brush, even a wire brush on an angle grinder, but it just melts the old adhesive.
Anton
Posted: Wed May 15, 2002 9:29 pm Post Subject: Re: Cork tile removal |
No Keith, not New Jersey. Jersey, Channel Islands. But no matter.
But thanks for answering |
Guest
Posted: Fri Oct 11, 2002 8:31 pm Post Subject: Re: Cork tile removal |
I've just had to remove 30 year old cork tiles from a bathroom floor. Hitting with chisels and hammers was too heavy for me as I have girly muscles so I had to find a different way. I used an old iron, set it on cotton/linen and left it on the cork floor for several minutes. Then I was able to scrape up an iron-shaped area quite easily as the glue had melted. It took ages but worked and most of the glue came up as well. I timed the work for when I was doing something else close by so that I could be getting on with something while I was waiting yet could keep an eye on the iron. |
Hamiltonandy
Joined: 22 Sep 2002 Posts: 114 Location: United Kingdom Thanked: 0 times
Posted: Sat Oct 12, 2002 8:41 pm Post Subject: Re: Cork tile removal |
Genius. Great use of iron!
________________________________
locked to prevent hi jacking |
