Hi all,
We're fitting a new toilet into what was previously a large cupboard in our utility room. There is an existing underground soil pipe within 2m of the external wall and we want to connect the waste into this. Can anyone help with the following:
- Will we need a soil vent stack? (Is that the correct term? - "vertical vent pipe outside the house wall"?) Can we go through the house wall, vertically down into the ground, and then along to join the existing pipe, or do we need a T junction outside the wall with a vertical pipe to act as a vent?
- Can we fit a 90 degree T intot he existing pipe, or should a Y shape connector be used to prevent blockages?
- What's the difference between brown underground soil pipes and the grey or black stuff used above ground? Are they the same size and interchangable?
- We want to put a basin waste into the soil pipe. What's best for this? Space between the loo and the wall is minimal at best.
All help appreciated.
Ant
Ant
