DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Roof valley and eaves construction
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
DaveyN
from United Kingdom
PostPosted: Wed Jul 09, 2008 7:32 pm Reply with quote
Hi guys, looking for guidance on curerent practise for constructing the eaves detail and valleys as my house is currently being reroofed and I need to make sure its going to be watertight.
The pitch is 43deg, rosemary tiles, breethable membrane and counter battens over membrane onto rafters. Membrane onto felt support trays. The problem seems to be that the joiner may have the facia boards to high, he says needed for kick on tiles but what is happening is that the counter battens are not going low enough so the first tile batten is having to be fixed directly to the support tray so defeating the object of letting water out. What is correct way to set this out.
Secondly the joiner has fitted floor boarding material for the lead valleys direct to the rafters but has laid the membrane underneath. I also cannot now see how battens can be fixed for the tiles other than nailing tiles to the floorboard material. What is normal practise with this.
Any help appreciated from roofing community.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1278 times
PostPosted: Wed Jul 09, 2008 7:50 pm Reply with quote
the valley boards are usually fixed between the rafters - sitting flush with the rafter top.
these boards should be wide enough to accommodate the lead or grp valley and have enough extra width to catch the roofing battens (lathes). also, there should be two battens running up each side of the valley to deal with the valley sides.
the fascia should be tall enough to provide a kick for the first course of tiles.
with plain tiles the eaves lathe will be rather close to the fascia. it does get quite cluttered at the eaves detail. we tend to use a strip of 12" dpm instead of eaves trays.
i have seen roofers fix the eaves first, then membrane on top, then the full courses of plain tiles.
why the counter batten? insulated rafters??
Back to top
 Alert Moderators
DaveyN
from United Kingdom
PostPosted: Wed Jul 09, 2008 8:10 pm Reply with quote
Hi, thanks for the reply, its a warm roof (between and under rafter insullation) construction and the architect has detailed the counter battens on the approved plans as he did the felt support tray. The counter battens nailed over the membrane on the rafters have been cut to the sides of the valley support boards only. No other battens have been fitted and the lead hasnt been turned up at the edges etc. hope that makes sense.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Roof and valley construction material/lifespan 2 140 Fri Nov 04, 2011 6:39 pm
Roof Construction 3 1160 Mon Apr 24, 2006 12:26 pm
Porch Roof - DIY construction 6 320 Fri Jul 06, 2012 3:21 pm
New construction roof design. 3 160 Wed Jun 26, 2013 2:24 pm
warm deck flat roof construction advice 4 1660 Sun Feb 27, 2011 6:08 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
