base for playhouse on stilts?
11 Jul 2008
Hertfordshire
Hi all,
We just bought this playhouse and were hoping to put it up this weekend. The instructions are a bit vague on whether we need to have a concrete base for it or not, what would you do? Can it just go on grass? If we use concrete can it just be under the feet?
[/img]
Yeh fine, in fact the less hard stuff the better for the kids heads, should they topple off of it. The bark in the picture is a good idea.
You could either dig a smallish hole, say a 18" cube, and fill that with concrete, or put down some extra thick paving slabs under each leg. Depends on what the ground's like really.
I built our own based loosely on a design similar to that posted.
View media item 2935
Under each leg I put in a concrete 'plug' with a quarter of a paving slab set on top.
View media item 2936
However, even though it is quite substantial I found that you could still get movement of the legs. So I drilled into the slab/concrete and put in a short length of reinforcing steel, leaving about 6 inches sticking up. I drilled a corresponding hole in the centre of each leg and lowered the frame onto the steel rods - no lateral movement now!
(obviously this can only work if you can put the base frame in first, and then put on the 'superstructure' later, because of the weight)
