Joined: 20 Dec 2006 Posts: 41 Location: United Kingdom Thanked: 2 times
Posted: Mon Jul 14, 2008 8:42 pm Post Subject:
Pipe layout advice required please
I'm putting the pipe work down for CH in a 2-up 2-down house I'm refurbing. RGI will be fitting the boiler.
I'm using plastic throughout except for where the pipes will be seen. I've read (here) that copper must be used within 1 metre of the boiler. Is this to safeguard the plastic against the hot water coming out of the boiler?
Altogether, there will be 6 rads and 2 medium towel rails. Can I use 15mm throughout?
Joined: 28 Oct 2005 Posts: 943 Location: Devon, United Kingdom Thanked: 27 times
Posted: Mon Jul 14, 2008 9:16 pm Post Subject:
Yes you must use copper within 1m of the boiler (some mnaufacturers state 1.5m)
I'd go for 22 on the main circuit, as a rule we never supply more than 2-3 rads off 15mm, depending on size. If you want to get scientific then there's a calc you can do to work out the pipe size - each size has a maximum capacity for thermal transfer over time, and it should really be matched to the rads you're fitting if you want to be really technical about it.
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Wed Jul 16, 2008 7:48 am Post Subject:
It is not just the size of the house that would dictate wether 22mm is adequate for the rads depending on what size boiler it will be in manufacturers instructions wether it stipulates a certain amount of 28mm pipework.
But in this case it would look unlikely
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
