DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
How to Sand and Cement Render?
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
  Bookmark and Share View previous topic :: View next topic
Author Message
wetcoat2
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 18, 2008 8:34 pm    Post Subject:
Reply with quote Thanks
Can anyone clear up some queries I have about sand and cement rendering as I hear contrasting opinions. I would like to Render a large block wall, hopefully whilst the weather is nice ;
1 Should I use sharp sand or building sand and to what mix per cement?
2 Do I apply PVA direct to the wall or add it to the mix?
3 To what thickness is the scratch coat applied?
4 To what thickness is the render in total?
5 What does it mean to float off using a wooden float?
6 Do I use mortar plasticiser or Lime to make the mix more pliable?
I have a good idea of the general principles but would like to clear up these points before I start slapping stuff on the walls.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
roughcaster
from United Kingdom
Thanked: 181 times
PostPosted: Fri Jul 18, 2008 11:00 pm    Post Subject:
Use plastering sand to cement render. 4 sand-1 of cement (4-1) for scratch coat with a combined waterproofer/plasticiser added. If the blockwork has a good enough key, you wont need to use PVA on the wall or in the mix. Just give the blockwork a wet down as you go, and apply the first coat to the wall say 6 or 7 mm thick, and then scratch it, ( an old 6" paint brush handle with "small" nails hammered in along the top works fine), scratch just deep enough to provide a key, but not right through to the blocks. There is no set thickness for the overall render, but the two coats combined would be around 15mm give or take the odd ml. The top coat, applied a day or two after the scratch coat has set and cured, would be a mix of 5 plastering sand, 1 of cement and 1 of lime (5-1-1). A waterproofer/plasticiser would be added to the water prior to mixing. Again, wet the wall before you top coat it.To "float off" using a wooden float, is to close up the render surface after being screeded/straightened off with the straight edge or darby. Floating is a process that is ongoing, and involves going over the same area of wall with the float a few times as the render goes through the stages of going off. When the render is at the final stage of "floating off", it is then sponged over (sponge finish)to give it more closer finish, and an even, slightly sanded texture.. There is a lot of work involved in cement rendering and if you're without experience, you have a daunting task ahead of you, but good luck to you anyway. A good dry day with not too much sun is perfect, you don' want it to dry out too quickly.
Roughcaster.
Back to top
 Alert Moderators
wetcoat2
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 04, 2008 10:57 pm    Post Subject:
Thanks mate, I'll give it a go on that solid bit of advice
Back to top
 Alert Moderators
MisterSandman
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 11, 2008 1:39 pm    Post Subject:
Which sand to use for rendering
Just a quick note - a Sharp Sand refers to the angularity of the grain. Make sure that any sand you use for plastering or rendering is suitable for the purpose.
Typical names include 0/2 Washed Medium Plastering Sand and 0/4 Washed Fine Plastering Sand, also Type A plastering sand and Type B plastering sand are sometimes used. Or just ask the quarry or builders merchants for a plastering/rendering sand.
Regarding sand/cement or sand/cement/lime mixes, basically you're aiming for each successive coat to be a little weaker than the last, to avoid cracking.
Hope this helps and good luck with the project.
Back to top
 Alert Moderators
Moderator 11
Moderator Comment
Posted: Tue Aug 12, 2008 3:36 pm    Comment:
Please note rule 3 (NO Free advertising.) - See here for the forum rules.
please familiarise yourself with Forum Rules
major
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 17, 2008 7:56 pm    Post Subject:
lime
hi roughcaster,
as i have never rendered, just interested in why the lime is used?
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 181 times
PostPosted: Sun Aug 17, 2008 9:52 pm    Post Subject:
Sand and cement render with lime mixed in it, gives the finished render coat greater flexibility, against any small structural movements when it's on the wall, and will greatly reduce the risk of the render cracking..... Sand and cement (render) on it's own, "having little or no give", is more liable to develop small hairline/movement cracks, although not always....... Lime in each batch also gives a good smooth texture to the mix itself, giving it great workability, making it far easier to spread etc...... A lot of stonework is also built using mortar with lime, again allowing flexibility to any movement in the structure,..... There's quite a few benefits in using lime........ I like the odd drop in a pint of lager too. icon_lol.gif
Roughcaster.
Back to top
 Alert Moderators
major
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 18, 2008 5:44 am    Post Subject:
Oh ok, brilliant I never knew that, thanks for the info.
I'm more of a beer on it's own man so if I should ever need to render I will just keep the lime in that mix icon_biggrin.gif
Back to top
 Alert Moderators
Jonnyboy40
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 12, 2010 2:35 pm    Post Subject:
Hi
I have an area of penetrating damp halfway up a wall. I've been told to use a sand/cement render with a salt retardant additive. Seems to fit with the advise above.
When I remove the existing plaster should I be removing it right back to the brickwork?
Cheers
J
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 181 times
PostPosted: Fri Feb 12, 2010 8:50 pm    Post Subject:
Absolutely,, remove it right back to the brickwork, then give it a good brush/wash down. Make sure it's got a good key as well. When you put on the scratch coat, make sure you don't scratch it too deeply, meaning, don't scratch right through to the brick themselves,, and use a good quality waterproofer/plasticiser.
__________________
Roughcaster.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 328 times
PostPosted: Fri Feb 12, 2010 8:59 pm    Post Subject:
Jonnyboy40 wrote:
Hi
Cheers
J
Jonnyboy40 please look at the last post dates; this thread is 18 months old, if you have a query, please post your own thread. Resurrecting old threads, no matter how relevant they may appear, causes confusion. icon_wink.gif
__________________
Richard C
Back to top
 Alert Moderators
gday2uk
from United Kingdom
Thanked: 12 times
PostPosted: Mon Feb 15, 2010 4:00 pm    Post Subject:
This is a very informative thread. Should be 'pinned' near the top or whatever they call it.... icon_idea.gif
Back to top
 Alert Moderators
thechief13
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 22, 2010 6:49 pm    Post Subject:
how to stop cracking when sand and cement plastering
i ve been doing sand and cement with skim finish for a few months and find that when the job as been done a couple of weeks later the walls start showing little cracks, is there any way to stop this thank you for your repiles
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 328 times
PostPosted: Mon Mar 22, 2010 6:58 pm    Post Subject:
Re: how to stop cracking when sand and cement plastering
Poor preparation; please post in your own name; do not hi-jack someone else's post & particularly not one that's 18 months old.
__________________
Richard C
Back to top
 Alert Moderators
thechief13
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 22, 2010 7:21 pm    Post Subject:
sorry new to this did not know
Back to top
 Alert Moderators
Micilin
from United Kingdom
Thanked: 80 times
PostPosted: Mon Mar 22, 2010 9:57 pm    Post Subject:
Roughcaster.
it also gives the render a bit of 'fat' - if you ever see a napped finish, you could not do this without the benefits of lime, and it makes it nicer to sponge up after floating.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Sand and Cement, Render, Screed 6 10060 Sat Jun 28, 2008 8:13 pm
sand and cement render on top of finish plaster 12 420 Tue Jul 06, 2010 11:27 am
sand 'n' cement? 7 820 Sat Aug 08, 2009 7:46 pm
Dot n Dab vs sand n cement 11 800 Fri Apr 16, 2010 10:27 pm
PVA mixed with sand or cement? 5 1260 Sat Aug 01, 2009 4:28 pm
FloPlast Waste Pipe 40mm x 3m Pack of 10 FloPlast Waste Pipe 40mm x 3m Pack of 10£39.98FloPlast SC250 Solvent Cement 250ml
FloPlast SC250 Solvent Cement 250ml£4.99
FloPlast 135 (45) Bend Grey 32mm Pack of 5 FloPlast 135 (45) Bend Grey 32mm Pack of 5£2.87FloPlast Waste Pipe Grey 32mm Pack of 10
FloPlast Waste Pipe Grey 32mm Pack of 10£32.98
FloPlast Pipe Clips Grey 32mm Pack of 20 FloPlast Pipe Clips Grey 32mm Pack of 20£6.49FloPlast ABS Access Plugs White 32mm Pack of 5
FloPlast ABS Access Plugs White 32mm Pack of 5£3.59
DIYnot
