Plane or Saw the Door?
  • Thread starter attractivebrunette
  • Start date
A
attractivebrunette
Ok, I've put underfloor heating and a new carpet in the bedroom. The door that I took off, is now too long to go back on again (because the floor has been raised by an inch or so). In order to put the door back so there is a small gap between the door and the new carpet (I dont want it to rub each time the door is opened or closed) should I try and saw a few milimeters off the door, or take it off using a plane?
I know I'm thick but any help would be appreciated.
If it is only a few mm's then plane it off. Plane in from the edge to prevent the splintering of the outer edges. It would be difficult to get a straight edge cutting a few mm's off with a saw.
It depends on the door.
You have to be careful with a saw as it will chip the underside face when you cut. Especially if the door is a solid one as you will be cutting along the grain on the bottom rail, but across the grain on the two end styles - so these may chip on the rear face
Same thing for a hardboard (embossed) door
Scoring the underside will prevent chips if using a hand saw.
But for less than 5mm, a plane would be better
to be able to saw material off a workpiece you need to be removing the saw cut plus about 5mm, so a minimum of about 8-10mm in total. anything less and the saw will 'travel'.
less than 10mm and i would reach for the plane. ;)
