system only fires up for 10 seconds then cuts out
7 Sep 2004
system only fires up for 10 seconds then cuts out then cut back in after a minute or so the baxi boiler is not a sealed system it has pump and 2 motorized valves (i take it this makes it a combi boiler) and a tank in the loft i have changed pump and valves tank in the loft is fine but the burner still only fires up for a short time ...getting desperate ..is there a thermostat in the boiler its self that could be faulty?
No its not a combi. You need a corgi engineer. Possibly a flame problem.
Does the pump actually run and circulate water?
Sounds as though the boiler might be firing, get hot and then turn itself off. Is the boiler internal thermostat turned right down
