Concrete Skirting
1 Jul 2008
Stirlingshire
i stay in an old property- at the front door i have a skirting which is made of concrete ! ! - i removed the gloss paint from them the best i can using paint stripper and sanding the question is now was the best application to get them glossed up white again ? - any advice on undercoat etc?
Are they right back to the bare cement?...if so id go for a coat of alkali resisting primer followed by a couple of undercoats and a gloss.
i ve tried my best to take them right back to the concrete although difficult! ive tried to use on of those paint removing pads you stick in a drill- which causes a hell of a mess but seems to work - on the primar - is there a certain make i should go for and also ? excuse me for being slow - how do i know it its alkali resist?
Any make will do..and its actually called alkali resisting primer.
If you cant get it back to the concrete then give it a good wash down to neutrakise the stripper, rub it down and undercoat it, then fill..undercoat again and then your topcoat.
Slightly off-post........
I came across concrete skirtings in an old property, all in pretty good nick and just needed a sand for key and a wash down, but they looked totally out of keeping with the rest of the house.
I fitted picture rail (upside down) on top of the skirtings, took the fine ridge off the back, caulked the gap and painted them up - took a few decades off the ambiance!
I did this in another place where there were BT wires and cables all over the top of the square-cut skirtings. Covered them up no problem.
