My wife and I bought a main door (ground floor) Victorian sandstone (circa 1890) flat/conversion in Edinburgh almost two years ago now. While a full survey at the time of buying mentioned an elevated (but not necessarily high) moisture reading in the back bedroom we until now have noticed no problems of 'damp'.
This weekend we noticed two separate damp patches on the wall above the skirting (one about the size of a kitchen sink; the other smaller) reaching to a maximum height of approx 30cm . The areas are separate by what appears to be completely 'clean' wall area - approx 1m apart. Would damp not affect all the length of that wall - at least with no breaks like in this example? Is this more likely to be penetrating wall damp?
Slightly more bizarrely is that the wall is not external to the outside environment. Our neighbours effectively share this wall as it forms a part of their hall for their conversion and stairs above (also made out of sandstone). However, approx 4 years ago they had their side treated (apparently successfully with an injection and re-plaster) for the same visual issues highlighted earlier. Could their treatment have effectively 'pushed' or forced the moisture internally to us?
Your help with this matter would be greatly appreciated.
Dan
Dan
