DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How to increase cold water pressure to electric shower
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Boxerman
from United Kingdom
PostPosted: Wed Jul 30, 2008 7:34 pm Reply with quote
My brother is having a problem whereby he does not have enough cold water pressure to run a decent electric shower. His water supply is via a borehole into a tank at upstairs level so only has approx. 8ft of head to the shower below.
What is the best way to increase cold pressure to the shower ?
Back to top
 Alert Moderators
cider
from United Kingdom
Thanked: 599 times
PostPosted: Wed Jul 30, 2008 7:51 pm Reply with quote
raise tanks in loft or get new electric shower suitable to work on low pressure
Back to top
 Alert Moderators
Boxerman
from United Kingdom
PostPosted: Wed Jul 30, 2008 7:57 pm Reply with quote
I believe he's tried 2 or 3 different showers at different outputs, any other options? I was wonedring whether he could pump the cold supply either directly to the shower or even a whole house pump on the cold side ? icon_confused.gif
Back to top
 Alert Moderators
cider
from United Kingdom
Thanked: 599 times
PostPosted: Wed Jul 30, 2008 7:58 pm Reply with quote
or if hes got cash to spend pump from the bore well to break tank then highpressure pumps to accumilator then back to cold mains icon_wink.gif
Back to top
 Alert Moderators
Boxerman
from United Kingdom
PostPosted: Wed Jul 30, 2008 8:34 pm Reply with quote
do I take it then that a pump between the tank and shower is not an option even with some sort of pressure regulator?
Back to top
 Alert Moderators
cider
from United Kingdom
Thanked: 599 times
PostPosted: Wed Jul 30, 2008 9:06 pm Reply with quote
never seen that on any installation manual before. cant imagine it would work and wouldnt try it
Back to top
 Alert Moderators
plplumber
from United Kingdom
PostPosted: Wed Jul 30, 2008 10:56 pm Reply with quote
get a stewart turner 3 bar pump (inc. pressure switch) supply it from the cold header tank and run the out put direct to shower. could also supply all cold from this if rest of plumbing suits.
i have done complete hot & cold house systems based on a combi boiler systems fed with pump & header tank before for bungalows. it works well and those ST pumps last forever as long as u don't run them dry!
in hind sight you could supply the pump through a electric float switch in the header tank so if the tank runs dry for any reason the pump goes off.
oh and another thing i always supplied the kitchen cold tap and toilets direct from the mains
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1101 times
PostPosted: Thu Jul 31, 2008 12:03 am Reply with quote
Common as eck, in top floor flats in London with tanks on the roof. You only need a small (silent, nearly, if you get a decent one) pump for an electric shower because the flow is low. 1.5 bar is fine.
No harm using higher if you want, but the shower will be the same.
Back to top
 Alert Moderators
simond
from United Kingdom
Thanked: 279 times
PostPosted: Thu Jul 31, 2008 6:29 am Reply with quote
Triton make an instant electric shower with an internal pump for connection directly to a storage tank. All you need in a box.
http://www.tritonshowers.co.uk/wps/wcm/connect/TritonShowers/Internet/Products/TritonShowers/Electric/T90xr+Pumped+Electric/
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Pump required to increase cold and hot water pressure 3 340 Thu May 13, 2010 9:32 am
Luke warm/cold radiators no pressure increase when boiler on 16 480 Sat Oct 20, 2012 8:38 am
Increase water pressure to shower pump? 4 1020 Thu Feb 26, 2009 9:31 am
Increase the water pressure in my shower? 2 380 Wed Nov 04, 2009 7:36 pm
Best way to increase water pressure to a shower 11 260 Fri Sep 05, 2014 10:07 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
