I have a Mira Advance Electric shower, approx 2 yrs old, with a totally unknown problem. The water heater 'tank' does not appear to have any residue, and still has some water in it, so I am assuming that it is not a water problem.
As it is 9.8kW, I cannot plug it into the 13a ring main and trailing a lead from the consumer unit to somewhere that I can connect a water feed, will be a problem.
Does anyone have a diagnostic procedure which I can use to establish what or whether there is a problem with it. I could connect a low voltage supply to test the circuit boards, or disconnect the heating elements and connect to the 240v
