DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
COOKER FUSES
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK
  View previous topic :: View next topic
Author Message
driver
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 04, 2004 8:42 am    Post Subject:
COOKER FUSES
Reply with quote Thanks
NEED TO REPLACE FUSE( TYPE Q O/E B.S.3871 PART 1.) IN THE CONSUMER UNIT CANNOT FIND REPLACEMENT, ANY IDEAS OF POSSIBLE SUPPLIERS.
THANKS
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 04, 2004 10:18 am    Post Subject:
BS 3871 (Part 1 - 1965) refers to circuit breakers, not fuses and they have been superseded by BS EN 60898.
If you are lucky a dusty old local wholesaler might still have one on the shelves, otherwise you'll need to consider upgrading your consumer unit, or adding an additional one.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Mon Oct 04, 2004 4:13 pm    Post Subject:
What make is it?? I may be able to tell you if a new version 60898 will fit in the same board.
Back to top
 Alert Moderators
driver
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 04, 2004 5:08 pm    Post Subject:
thanks for the reply,
It's the consumer unit in our Scout group thats causing the problem, it's wired for a cooker but it trips the circuit breaker when you use 3 or 4 rings at once.
Would think the unit is about 15 years old as this is when the building refurbished. All we can see on the circuit breaker is:-
type Q O/E B.S. 3871 part 1,
240v 1ph. 50-60hz,
415v 3ph 50-60hz
there is also a name, SQU-RE not sure what the middle letter is.
Many thanks again.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Mon Oct 04, 2004 5:15 pm    Post Subject:
Not square D?? Their old boards are obsolete now, no breakers anywhere.
What rating is the cooker?? (k-watts). Has it always tripped, or more recently??
Had any electrical work done to the kitchen?? Extra sockets etc??
Plug anything into the socket (if any) on the cooker switch??
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Mon Oct 04, 2004 5:18 pm    Post Subject:
you really need a sparky
i suspect he will have to change the whole board to uprate the one cuircuit
Back to top
 Alert Moderators
treacleman
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 04, 2004 6:16 pm    Post Subject:
Square D QO-E breakers are available, the boards may be obsolete, but they still supply the MCBs. Try any Electrical wholesaler, they will have a source for them.
you might have to pay over the odds, but hey, cheaper than a new CU.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Mon Oct 04, 2004 6:18 pm    Post Subject:
Square D did a board with breakers slightly wider than usual. These ARE NOT available anymore. A company bought up ALL the mcb's from Square D, and they are available through wholesalers, but they only have 3ph C10's left.
Back to top
 Alert Moderators
treacleman
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 04, 2004 8:04 pm    Post Subject:
You're confusing them with Federal Lectrician, a company in Birmingham bought all of the old Federal MCB's and as you suggested, have only 10A TP and 6A TP ones left now.
I assure you, the Square D QO-E range is STILL available.
They are the ones with _(_)_ shaped terminals top and bottom.
Back to top
 Alert Moderators
Damocles
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 04, 2004 9:30 pm    Post Subject:
You have not said why you think the mcb is faulty yet. MCB are supposed to trip if something is drawing too much current. Quite sure there are no cracked rings on the cooker, might be pulling more curren than it should?
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Tue Oct 05, 2004 6:54 am    Post Subject:
You have me bang-to-rights. We have been trying to source federal ones for a while, with no luck. Everyone keeps saying square D will fit - which it doesnt. This is where my confusion has come from. (i have sq d on the brain). Either make is cr*p though icon_biggrin.gif
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Oct 05, 2004 9:28 am    Post Subject:
You may have thought of this, but have you asked the boys if any of their parents are electricians?
Or the parents in any other regular users of the hut, if there are any?
I'm almost certain there will be public liability issues with any non-qualified person working on the electrics.....
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Oct 05, 2004 8:30 pm    Post Subject:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=3188&item=5925326956&rd=1
__________________
Back to top
 Alert Moderators
geordieboy
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 26, 2007 7:41 am    Post Subject:
Square D Circuit Breaker
____________________________________________
Lynda, moderator.
Welcome, please read the forum rules.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 1 of 1
Jump to:
cooker and hob need seperate fuses? what can i do? 4 340 Wed Dec 19, 2007 5:32 pm
Cartridge Fuses 2 500 Thu Jan 19, 2006 7:57 pm
Switched Fuses 9 2160 Tue Jan 24, 2006 7:44 pm
Replacing Wylex wired fuses 8 900 Tue Mar 07, 2006 5:27 pm
Dimmer not dimming then fuses 13 2420 Sat Dec 03, 2005 2:05 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
