All the lights on a lighting circuit now fail to function, although a flicker was seen to continue from a fluorescent light after the fault occurred. I have measured a voltage of about 20 to 30 volts across the terminal of a switch suggesting (to me) that the circuit is intact and the fault lies elsewhere, probably in the MCB (type B6). Before I call in an electrician, could anyone suggest an alternative explanation?
