bosch cassixx dishwasher
26 Jan 2008
Yorkshire
It seems to be stuck on rinse, The 2 rinse lights are on (AID & SALT) and the drain pump just keeps running. any ideas anybody?
BOBBY.
Cheers for that, "Base Flooded" What should I do ? Why would the base be flooded if the pump is running all the time?
When I pour water into the compartment the pump, pumps water out ok
I drained the base, and the washer started to run, but the 2 rinse lights stayed on. after 5 mins of running it stopped again with the same prob.
if the on/off button is on and the door is opened the pump still runs.
bobby.
If there was water in the base there is a leak,Check all seals and also that the nut on the saltbox is tight.Also check pressure chamber is clean.
