I'm building a series of raised planters in 21.5 wide hollow dense block that will be rendered and painted.
In the middle I want to build a 2m high x 1.35 wide wall (3 blocks x 9) using the same blocks with a waterblade feature in the middle.
Searching the net implies that anything over 1m needs professional design. As this won't be weight bearing and only needs to look nice, can anyone foresee a problem if I make sure the foundations are more than adequate?
