neilcoltman
Joined: 05 Oct 2004 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Tue Oct 05, 2004 2:37 pm Post Subject: main tails |
What is the correct size that your main tails from your main box to your electrical meter supposed to be.In my house they are 16mm but in most shops they sell 25mm. |
L.Spark
Joined: 12 Jul 2004 Posts: 61 Location: United Kingdom Thanked: 0 times
Posted: Wed Oct 06, 2004 4:25 am Post Subject: |
16mm is fine for your house, you most likely have a 60A or a 80A main fuse, if you needed to have more power, then you would have to speak to the electricity company about having your fuse uprated to 100A, only then would you need 25mm tails. |
salem2000
Joined: 10 Feb 2004 Posts: 598 Location: Essex, United Kingdom Thanked: 0 times
Posted: Wed Oct 06, 2004 11:03 am Post Subject: |
I would use 25mm tails, at least then when/if you upgrade your supply main fuse the job is already done. __________________ 1010011010 |
Lectrician
Joined: 18 Jul 2004 Posts: 5166 Location: Devon, United Kingdom Thanked: 20 times
Posted: Wed Oct 06, 2004 12:12 pm Post Subject: |
Yea, I always install 25tails, 16earth.
BUT don't worry too much if your tails are 16mm with a 10mm earth, as said before, most services are fused at 60 or 80amp, even though it says 100amp on the carrier (this is the maximum current, not size of the fitted fuse.) |
