indesit wg820
6 Oct 2004
recently given this washing machine now wont drain or spin. been told to check the filter but i don't have a manual and cannot find a filter any more ideas. thanks. :confused:
i would agree with what you have been told, find the filter ( some where near the pump?) or the pump / its connections.
reason being the pump pumps out the water (obviously) so it wont drain, but if its got tooo much water a m/c should not spin.
uoi may also want to read this post they had similar problem to you, and indeed it was the filter
Is there a small panel at the front bottom of the machine ? usually push fitted or single screw. If so this is access to the filter to make it easy for you to inspect and clear.
