fhawkes
Joined: 20 Aug 2008 Posts: 4 Location: United Kingdom
Posted: Wed Aug 20, 2008 5:22 pm |
Hi
I am a novice DIYer and have encountered a bit of a problem... I was stripping wallpaper and unfortunately someone had papered up onto the cornice, the paint has flaked off in this area, I have continued to peel the paint off to the point where it stops coming off easily. The question is do I need to strip all the paint off the cornice? Or is there an easy way I can do it and end up with an even result - i.e. sanding with fine grade sandpaper to smooth the different levels of paint.
The cornice has been painted with several layers of oil based paint and there seems to be a red distemper underneath. The house was built around 1890. Also it seems like there has been a damp problem many years ago and some of the cornice has cracked. Can I fill these with polyfilla or should I use skim coat that I have used elsewhere in the flat?
Why oh why did I not buy a new build?????
Any help and advice gratefully received!
Fiona |
fhawkes
Posted: Thu Aug 21, 2008 1:18 pm |
ok currently I am stripping all the paint off that length of cornice, it is just flaking off with a shave hook. I plan to fill cracks etc with skim plaster...
ANYONE am I doing this correctly? |
Zampa
Joined: 14 Mar 2005 Posts: 5778 Location: United Kingdom Thanked: 23 times
Posted: Thu Aug 21, 2008 6:39 pm |
Yep..its a tricky one Fiona..the distemper is whats causing your grief..
If you have any flatish areas you can stick duck tape on them and pull it off..it often takes the paint with it.
youl need to remove as much of the distemper as possible because it doesnt take traditional paint very well..try and take the paint back to a sound part, wash it of and seal the residue with zinser bin primer or alkali resisting primer.
Horrible job..im glad its you doing it and not me  |
fhawkes
Posted: Thu Aug 21, 2008 9:10 pm |
Thank you!
Genius idea using duct tape - I have resorted to using jet nozzle of my steam wallpaper stripper but having to be very careful not to wet any one area too much.
Not sure what the primers you are talking about are. I had thought of using diluted PVA as I would to seal plaster... probably not supposed to do that
Thanks again, all advice and reassurance gratefully received!!! |
Zampa
fhawkes
Robbie uk
Joined: 09 Apr 2007 Posts: 1308 Location: Cheshire, United Kingdom Thanked: 135 times
