MIRA GO 9.5 electric shower
11 Apr 2008
Berkshire
Help would be appreciated. I`m planning to fit the above mentioned electric shower. The installaion shows the cold feed to be connected to the bottom of the shower unit. Do I have any options on how to run the pipe work from the cold water cistern to the shower. Currently the wall is tiled and the last thing I want to do is remove the tiles to dig the wall out or is this my only option.
run the feed external down the wall into the shower.
it will take either a top,bottom,back entry.
Sorry for the daft question but is this a common way having the external pipe work running down the wall to the unit. Also how can I make the appearance as neat as possible. I want to avoid seeing the nasty copper pipe work. Thanks for your suggestions.
it is common on bathrooms that are already tiled etc.
if you want it to look tidy use chrome plated copper pipe and a couple of chrome pipe clips.
will look tidy then.
but you'll still have an ugly cable conduit going to the shower.
