mimimum size
17 Feb 2008
Berkshire
I wanted to do my bottom landing from stairs in engineered too, but the size is only 1.3m x 1.1m.
Would this be ok or is the area too small?
It depends on building regs, give your local council building control a call.
Stairs can be a nightmare, I sed to live in Slough and had loads of hassle when I wanted to change the way the stairs ran.
Tony
Sorry I misunderstood you request, I thought you wanted to replace the bottom with engineering bricks :oops:
What is engineered when its at home?
Tony
there is not really any area to small!
As long as those small areas are level and the wood is glued/pinned down.
You might have a problem if the boards are bevelled though. And if the step(s) are tapered you end up with a lot of saw-waste
