timer for outside light
6 Aug 2008
Cumbria
Hi guys I have fitted an external lamp which has a 240volt - 40watt bulb and I will be connecting a dusk till dawn sensor in line can I use a 3amp digital timer in this circuit or will the load be to much for it. I was looking at this one on screwfix,
http://www.screwfix.com/prods/92842/Electrical/Timers/Digital-Timer-Switch-Frame-3A-240V
I do not need this on all night long that is why I want to use a timer and there is not room in the fitting for an energy saving bulb, it is merely a light with the house number on it facing the path so people can find the house in the dark
Hate to get his 'leccy bill! :eek:
Obviously meant 40W
(at least I hope he did! :LOL: :LOL: )
I hope so too unless the outside light looks like this....
Its because you said
240volt - 40amp bulb
that you are getting The P taken
I dont see the point of having a timer and a photocell.
why not get an "energy saving lamp" with built in photo cell (they do exist)
that way it uses less electricery, (yes i did mean to spell it that way) and no additional timer / photocell req'd
I've use the same arrangement on many occasions as some people don't want lights on all night, low energy or not. The timer will guarantee a switch off time and the photocell means constant changes to the timer as lighting levels change over the year won't be required.
