I have recently replaced my front door with a upvc door from www.u-fit.com.
The door is great and much better than the old wooden one I had but I have a couple of problems with it.
Firstly, I found that the opening side of the door was dragging slightly on the floor but after following guidelines on Toe & Healing I think I've sorted that one.
The problem I need answering here is that the top of the door, when closed, isn't meeting the frame fully. There is 3-4mm gap. The gap seals when I deadlock the door but causes quite a draught when just on the latch.
I have tried adjusting the hinges in every way I can think of, the only time I managed to get rid of the gap I couldn't open the door as the dragging (as in my first problem) got too bad. I have measured everything and the frame is perfectly square and level. Now I have fixed my Toe & Heal problem can anyone advise how to get rid of the gap?
