Soil pipe cover
26 Feb 2006
Tyne and Wear
I have a cast iron soil pipe but there is no cover on it. It's outside diameter is about 110mm.
B&Q say they don't have a suitable cover.
Can I buy a ~100mm plastic cover and use mastic to attach it. (I believe there is a risk of blocage if I don't seal it).
From a DIYer not a Plumber
If the stack is not used and you simply want to cap it and the pipe's OD is about 110mm you might be able to get a double socket on it (search screwfix for part no 47977 for picture) If you can get that on you can stop the other end with a socket plug (46863). You'll spend less than a tenner on those two.
If not, you might have to buy the equivalent in cast iron. One or other of your local merchants will stock the "timesaver" range. It is a range of cast iron components, rubber seals for different pipes and clamps to make them water and airtight. I'm not sure whether they do a socket plug per se but you could adapt to the plastic sizes if required. I've used them only three times in the past for repairing a broken section in a cast pipe and adding a branch to a stack but they're easy to use but expensive.
EDIT - perhaps you mean an open cover simply to prevent large debris entering.
Hopefully the experts can advise you further.
Visit wickes, get the cover for about £2 although it is 100mm cut the side and it will slide over tight,use no nails to bond it.........done this about 4 years ago with mine and still intact
wow, thank you all for the responses
sorry I wasn't clear
The cover is for the top of the soil stack (above the gutter line).
I'll try JOHNBOY42's idea and visit Wickes. (Our local B&Q had only a plastic cover and it seemed a lot at £14)
Thanks again
Pete
If it's above the gutter line it may need to be open, in which case something like a Screwfix 33239 soil pipe terminal may need to be used. It leaves the pipe open to equalise pressure in the system but stops leaves and other debris going down the stack.
