Removing sealed unit
13 Nov 2006
Kent
Hello, I need to remove the sealed unit from a upvc window frame on the front of my house. The frame is externally glazed, with the rubber strips running round the glass internally on the frame, how do I get the glass out without wrecking the plastic beading?
iirc you gently prise out the rubber,this in turn releases the pressure on the trim outside and then they should be a lot easier to remove.
