Radiators not heating up but hot water working
25 Aug 2008
Argyll
Boiler is producing hot water but radiators are not heating up. Most radiators are on but the main radiator is leaking slightly at the valve - only needs tightened up - would this affect the entire system?
you have overwhelmed us with the amount of information you have provided us.
have you tried turning it on ?
All radiators are switched on and turned to max., thermostat switched to highest temp and heating and hot water options are both selected. Timer overiden also.
what sort of boiler ?
what model ?
sealed system ?
are there cold water tanks in loft ?
is there a h/w cylinder ?
what controls are fitted ?
2 or 3 port valves etc ?
