Make fire place larger
9 Apr 2006
Blackpool
I intend to install a wood burner to fit inside the fireplace, But i need to make the actual fire place larger to fit the wood burner in, I need to take out around 15cm each side, would I need to fit a lintel to support the bricks above? I would like some advice how to do this and if it is going to be difficult. I intend to get a quallified fitter to fit the burner.
do you live in a modern house or an older house?
in older properties the builders would build the fireplace and chimney breast with a large lintelled opening that would be later filled in with whatever design of fireplace specified.
the 'builders opening' may be 3 feet or more in height with 9" pillars forming the sides.
Yes the house was built in the 30's at the moment the opening is around 40cm wide and 70cm high
