Guest
Thanked: 0 times
Posted: Fri Dec 20, 2002 2:31 am Post Subject: cutting ceramic tile |
hi im lkaying ceramic tile i have a dewalt circular saw 7 1/4 in bought sdome blades from canadian tire that are for masonary they would cut one tile then they went dull do you have any ideas ? i tried even watering the blade as i cut but still no goood plese email me back thanks harry |
Guest
Thanked: 0 times
Posted: Sat Dec 21, 2002 11:08 pm Post Subject: Re: cutting ceramic tile |
Hello What email address, the answer is ceramic is not quite the same as masonary that is why the blades go dull, you needa ceramic cutting disc, have you heard of a "do all" disc? (advertised on infomertials)
cuts anything and has a liftime g'tee so if you do dull it send it back and get another one free
__________________
David Jones |
diyslave
Joined: 08 Jan 2004 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Thu Jan 08, 2004 3:50 pm Post Subject: cutting tiles |
try this place for the do all disc
another way is get a small diamond blade that those small electric tile cutters use(like a table saw),these blades fit an angle grinder,if your lucky it may fit your saw too |
aaront
Joined: 23 Jan 2003 Posts: 112 Location: United Kingdom Thanked: 0 times
Posted: Thu Jan 08, 2004 4:20 pm Post Subject: |
B&Q are selling a stand alone ceramic cutter for £30 approx.
We've used it - excellent job |
GwaiLo
Joined: 30 Dec 2003 Posts: 100 Location: United Kingdom Thanked: 0 times
Posted: Thu Jan 08, 2004 4:25 pm Post Subject: |
I have used the B&Q job too, great for DIY jobs. __________________ This is not advice. Seek professional advice. I accept no liability errors or omissions. |
antinator
Joined: 06 Jan 2004 Posts: 11 Location: United Kingdom Thanked: 0 times
Posted: Mon Jan 12, 2004 11:10 am Post Subject: |
are you cutting tiles straight if so use a tile ciutter but i dont know wat its called but u have to use man power instead of machine it really easy to use and most diy store have themk its really just a small blade on a sliding bar which u bring across and the push down and cut the tile |
