In one of my treatment rooms, I need to remove a radiator for me to cut a new doorway and this means, unfortunately, that there is no space to relocate it as all the remaining wall space is already utilised.
A client mentioned a hybrid heater that in effect uses a small radiator and a blower fan.
I'm unfamiliar with this sort of product but in theory it could solve the problem and could be mounted above this doorway if shallow enough.
The CH microbore comes down the wall from the 22mm supply and return above a suspended ceiling and I also have an adjacent ring main there too, so the connections could be quite convenient.,
Does such an item exist? If so is there a choice of makes and qualities / reliability?
All constructive comments will be gratefully received. Thank you.
