DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How long between coats ?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
Author Message
rampump
from United Kingdom
PostPosted: Sat Sep 20, 2008 8:36 pm Reply with quote
Hi all,
I've just put the first skim (Thistle Bonding - Purple logo) on the first wall I've ever plastered.
Its gone on OK and appears to be drying out OK. It is on to a thickness of about 2mm - 3mm
How long do I wait before doing the final top coat ?
Realise its a basic question, but I've never done this before and don't want to make a DB out of it now by top-coating too soon or too late
Many thanks
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 533 times
PostPosted: Sat Sep 20, 2008 10:34 pm Reply with quote
If you've just skimmed the wall with Thistle bonding coat, then that is undercoat plaster and you will have to wait for it to set before you can put on the Multi finish (finishing plaster). That comes in a white bag with orange writing/logo. Have you got a bag of multi? You'll know when Bonding coat is beginning to set because you will see it change from the light colour to darker, patches will appear in it and when it has completely set it will be darker all over. That is when you should put on the finishing. You can put it on earlier but this can cause blisters/bubbles.
Roughcaster.
Back to top
 Alert Moderators
rampump
from United Kingdom
PostPosted: Sat Sep 20, 2008 10:40 pm Reply with quote
Cheers Roughcaster
Does it have to be Multi Finish ?
I don't have a bag of that, bought Green bag (finishing coat, I think)
If it has to be the former, I'll go back & swap bags ......
Back to top
 Alert Moderators
roughcaster
from United Kingdom
Thanked: 533 times
PostPosted: Sun Sep 21, 2008 3:11 pm Reply with quote
What you have in the green bag is Board Finish, for using on plasterboard. I would use Multi finish, it can be used on plasterboard or on a solid floated surface, most would use it nowadays........ One more thing, if you have coated the wall with bonding, and are now thinking of putting on the finishing plaster some 2 or 3 days later, you will have an awkward job. Most, if not all walls that are coated with plaster, be it undercoat or just multi finish skimmed, are completed the same day. In other words, start and finish the wall/s on the same day, don't do one coat today and another one tomorrow. It makes for very hard work..
Roughcaster.
Back to top
 Alert Moderators
rampump
from United Kingdom
PostPosted: Sun Sep 21, 2008 3:36 pm Reply with quote
Thanks again Roughcaster ........ it was the 'do I do it all on the same day' which I needed to know, and now you've kindly answered it icon_biggrin.gif
I tried earlier to do a thin coat with Board Finish ...... gave up after 2 float-fulls !
Stuff was damn near setting on the float and went onto the wall like a half-solid turd - scraped off easily enough though
Remixed another sloppier mix of bonding (all I've got in) and that went on fine, but have now run out, with about 4 sq. ft. remaining icon_evil.gif
Still, am enjoying the learning experience, not least how much plaster can I wear icon_lol.gif icon_lol.gif icon_lol.gif
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Sun Sep 21, 2008 8:53 pm Reply with quote
Bonding is not a finishing plaster, won’t give a satisfactory result & your wall will look pants; get yourself a fresh bag of Multi finish & use that. If you’ve let Bonding dry out, it will suck like hell & you will need to give it some serious PVA before attempting to skim with Multi. Apply one PVA coat which will probably get totally absorbed by the Bonding & let it dry thoroughly; when your ready to plaster, apply another liberal coat of PVA & then another immediately over that & away you go but it will still be a bit quick on ya!
Back to top
 Alert Moderators
roy c
from United Kingdom
Thanked: 319 times
PostPosted: Sun Sep 21, 2008 8:58 pm Reply with quote
Like richard said or get a garden water sprayer and soak the wall all over till the water is not absorbed then skim it .....You could skim it with your board finish shouldn't make any difference if youv'e killed the suction... icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
Coats of bonding 12 820 Mon Nov 16, 2009 8:31 pm
1 or 2 coats of multi-finish????? 17 1580 Mon Feb 22, 2010 6:53 pm
Advice on plastering coats please!! 5 560 Sun Apr 12, 2009 10:48 pm
Length of time between coats 2 660 Mon Nov 05, 2007 8:42 pm
Skim Coat one or two coats 8 1680 Fri Oct 19, 2007 4:29 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
