Cold radiator, tried everything i can think of
23 Sep 2008
Birmingham
Since moving into my house last year I have always had one radiator not heating up in a bedroom.
The pipe into the trv is very hot where the pipe on the other side is cold.
I have replaced the trv, removed and cleaned the radiator, bleed all radiators, turned off every radiator apart from this one but still does not heat up.
While the radiator was off the wall I opened both valves and water came out both, slightly more pressure out of the trv.
Anyone have any idea on what else to do?
The radiator is full of water and hot water will flow through to the bleed tap when I bleed it. It's just the water will not flow through it for some reason.
Might try replacing the valve the other side although it seemed ok.
Could be that it is plumbed in wrong. Both pipes connected to the flow, or return?
To me it sounds like its filling up via the return pipe and thats why its cold.
Replace the other valve and remove the 2 tails from the rads, then try clean out the rad with a garden hose.
Stick it all back together.
Does hot water come out of the flow pipe?
Found that was the exact problem after taking the floor up.
When the house was built there was 4 pipes from 2 radiators coming through a joist. The builders obviously got the pipes a bit mixed up. Which also explains why my other radiator never got very hot.
Thanks for everyones replys, glad to have a warm room again :)
