DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Glow Worm Space Saver mk 2
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
trix
from United Kingdom
PostPosted: Wed Sep 24, 2008 9:07 pm Reply with quote
Can anyone help i have a Glow Worm Space Saver mk 2 running on lpg, got new gas bottles and went to fire it up and nothing held in the button for ages and kept trying the igniter but it just wont fire!
I have had the covers off and it doesn't seem there is any gas getting through as i cant smell gas when i have held the button in for ages??? it was all working last winter and has been off for about 6 months??
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 407 times
PostPosted: Wed Sep 24, 2008 9:27 pm Reply with quote
Stale gas in the pipework.
You need a (LPG) RGI to purge the pipework through.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 773 times
PostPosted: Wed Sep 24, 2008 9:55 pm Reply with quote
Check the UPSO on the regulator hasn't operated and shut the gas off.
Very common when bottles have been changed.
Back to top
 Alert Moderators
trix
from United Kingdom
PostPosted: Thu Sep 25, 2008 4:05 pm Reply with quote
Thanks for the feed back, the situation now is..... i have cleaned out the feed pipe to the boiler and checked that gas is getting to the boiler valve by disconnecting the mail feed in to the valve and gas is reaching there! But still i hold the green button in for aged and nothing happens, the valve is a (Honeywell V4700E) which i have sourced for around the 50 mark but am not sure if this is needed or can i try anything else first maybe thermocouple???
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 297 times
PostPosted: Thu Sep 25, 2008 6:17 pm Reply with quote
The pilot injector will probably be blocked.
Not a DIY job!
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 421 times
PostPosted: Thu Sep 25, 2008 6:21 pm Reply with quote
try a RGI - gas can be dangerous in the wrong hands.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Glow Worm Space Saver problem - boiler wont start or fire up 9 4300 Sat Dec 08, 2007 10:48 pm
GLOW WORM SPACE SAVER 38 GAS VALVE WANTED 11 1960 Fri Oct 19, 2007 9:22 am
Glow worm space saver 22-30 b stopped working after new rad 6 800 Sat Nov 25, 2006 4:57 pm
Glow Worm space saver ksb 30 - No spark at boiler burner 17 540 Mon Nov 22, 2010 3:05 pm
Glow worm Space saver MK2 ~ wont fire the main flame. 2 780 Wed Sep 12, 2007 6:54 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
