DIYnot
Local | Network
   DIYnot > Forums
Local | Network
key stuck in lock!!
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
noviced1y
from United Kingdom
Thanked: 1 time
PostPosted: Thu Sep 25, 2008 1:51 am Reply with quote
I have a 100mm euro cylinder lock on my front door and the key is stuck and will not turn in any direction. Any suggestions on how to turn the key so I can remove and replace the cylinder?
Back to top
 Alert Moderators
glassgod3
from United Kingdom
PostPosted: Thu Sep 25, 2008 2:26 pm Reply with quote
Try gently with a set of pliers.
Back to top
 Alert Moderators
mattylad
from United Kingdom
Thanked: 143 times
PostPosted: Thu Sep 25, 2008 5:03 pm Reply with quote
squirt WD40 in from the other side, remove handles, push another key in from the other side to try & dislodge it?
Back to top
 Alert Moderators
glassgod3
from United Kingdom
PostPosted: Sun Sep 28, 2008 12:53 pm Reply with quote
Was my post edited ?
Back to top
 Alert Moderators
allaspects
from United Kingdom
PostPosted: Tue Sep 30, 2008 11:11 am Reply with quote
i have been repairing all dg for 25 years, wd40 to start basically wash the lock out put plenty of tissue on the floor under the door, gently wiggle and pull the key until it frees(the pins in the lock have jammed the key, years of atmospheric dirt) when key is free carry on washing out the key barrel, lots of black gunk will come out. if all this fails .....
Back to top
 Alert Moderators
theoutlaw
from United Kingdom
PostPosted: Tue Sep 30, 2008 2:39 pm Reply with quote
Tony
Back to top
 Alert Moderators
Jaffa72
from United Kingdom
PostPosted: Tue Sep 30, 2008 4:54 pm Reply with quote
I guess it wont be long before the mods are editing/deleting other posts on this topic icon_eek.gif
This topic is treading on dodgy ground when it comes to advice on how to get a lock open(can you see where im going with this?)
Back to top
 Alert Moderators
theoutlaw
from United Kingdom
PostPosted: Tue Sep 30, 2008 7:31 pm Reply with quote
Exactly, at least the op says there is a key stuck in the lock.
Tony
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Tue Sep 30, 2008 7:46 pm Reply with quote
Tony
Can you vouch for the OP - do you know him/her ?
With regard to security - some advice is given far too freely, without consideration of the OP's motive. Granted, the information is often available via other sources on the web - but that doesn't make it ok to post here.
Back to top
 Alert Moderators
theoutlaw
from United Kingdom
PostPosted: Wed Oct 01, 2008 10:34 am Reply with quote
HandyHands wrote:
Tony
Whit Wooo, get you!
The OP has asked how to get a key that is stuck in the lock out, not how to remove the lock. Or break the door down without being heard.
Why quote me when I am agreeing about the security issue's with locks on forums?
Tony
Back to top
 Alert Moderators
glassgod3
from United Kingdom
PostPosted: Thu Oct 02, 2008 1:30 pm Reply with quote
With all the stuff in the press recently about the problems with euro's i do not think they need to be told by us how to snap a euro
Back to top
 Alert Moderators
Moderator 11
Moderator Comment
Posted: Thu Oct 02, 2008 1:54 pm    Comment:
However, we generally do not like to see advice here, on how to break in to houses, or commit certain other acts, so some posts may be edited or removed.
theoutlaw
from United Kingdom
PostPosted: Thu Oct 02, 2008 1:56 pm Reply with quote
Robbie uk wrote:
Take the handles off. ............. Esay Peasy.
No disrespect to Robbie, but what is this then?
Tony
Back to top
 Alert Moderators
glassgod3
from United Kingdom
PostPosted: Thu Oct 02, 2008 2:41 pm Reply with quote
Exactly like outlaw has just posted, and i was not telling them how to break in(just as well smash the window) i was telling them how to take the euro out, ........ you still have to turn the locking mech so it opens so unless you know what you are doing it is not really that quick and easy imo
Back to top
 Alert Moderators
Robbie uk
from United Kingdom
Thanked: 179 times
PostPosted: Thu Oct 02, 2008 5:46 pm Reply with quote
Yeah! appreciate why the mods stepped in...
Back to top
 Alert Moderators
kirkscoobz
from United Kingdom
PostPosted: Tue Nov 03, 2009 1:05 pm Reply with quote
This is quite a common problem with euro cylinders, mole gip the key, then gently pull out wards, theshould then come out.
If the key will move, but wont come out, take the lock out, then remove the key, the lock then will have o be picked from both sides halfway around, then move the central cam to the bottom, you can then put your key in ten turn back to normal, do this on both sides, hen re insert the lock, problem solved.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Trying to change stuck UPVC lock cylinder 12 260 Sat Feb 21, 2015 10:33 pm
Mortice lock bolt stuck out 3 520 Sun Aug 23, 2009 8:27 pm
3 way lock stuck 5 120 Sat Oct 29, 2011 3:34 pm
Dead lock on upvc door stuck 3 100 Tue Jun 12, 2012 5:50 pm
Legge Mortice Lock Stuck Shut - Key broken! 15 240 Wed Mar 12, 2014 5:52 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
