Everything going wrong, HELP!!
15 Oct 2004
My boiler supplies a tank which then supplies the radiators and hot taps. Suddenly the pilot light no longer stays on, as soon as i take my finger off ignition it goes out, and it never flares up. Aslo have electric switch which heats the hot water but not the radiators (not sure if its meant to) also had new tap fitted, i fitted new kitchen mixer tap but no hot water will come out (thats when the hot water is on electrically) any advice???? :(
Sounds like the thermocoupe has gone on the boiler. You need to get a corgi plumber to fit a new one.
The electric switch is probably the immersion heater fitted to the hot water cylinder. It will only heat the hot water not the radiators.
with your mixer tap, will it run hot water if the cold water is turned off ?
