baxi solo 2pf fault
15 Oct 2004
ive replaced my pcb but to no avail. still no hot water and heating. it seems electrically sound is 10years old and is in good condition. the fan tries to start and is working. the fan tries to start and \\\'fan on\\\'light flickers when i fiddle with the connection on the side of the boiler, not the cable that goes up to the top to the fan but the other one. im guessing this component is faulty, should i replace it and what is it??
any ideas and comments please im freezing,!
thanks
steve :idea: :?: :(
Why did you replace the PCB. What prompted you to do that. Surely, calling out someone who repairs boilers for a living would have fixed your boiler for less. You would not be cold now.
You being cold does not give anyone any clues as to what is happening in your boiler.
venturi often blocks on these boilers as does the pilot causing the symptoms you describe, or as kev says maybe the aps or one of the air hoses
