Foundations - strip or raft
18 Feb 2006
Birmingham
Building a shed/store in the garden (30sqm) out of 6" solid concrete blocks.
What would be better strip or raft??
There is already some bit of a raft from the base for an old shed
im digging 800mm down, how much should concrete be?
cost or thickness?
you will require a minimum of 225mm thick concrete though economically it is sometimes better to mass fill.
i thought you would be further on by now playa. :LOL:
cost or thickness?
LOL noseall;
Things just have'nt gone my way. Been so busy with work and messed around by people - getting ridiculous.
Finally managed to get someone to move the 1000 blocks to the rear for £50 - its a start
Today i managed to cut the old slab with a disc cutter where it is in the way for the trench.
Actually the brickie I got doesnt mind mixing up the concrete, what would be the cost for 225mm thickess x 450mm wide x 22m long be to buy materials???
it will take a little under 2.5m3
you will need 5t ballast and 33 bags of cement.
average cost (trade) about £295.
Finally started the digging, should be done tomorrow. Then just need to order the concrete and level it out to start blocking up to dpc
@noseall,
After pouring the concrete, and building up 3 rows of blocks (220mm above ground), do I just use a dp membrane on the floor and over lap it over the block for the dpc or do I have to use seerate dpc for blockwork?
Also what thickness should the concrete floor be ontop on what thickness hardcore? Its only to be used as a shed and no vehicles
lap the dpm onto the blockwork plus a dpc layer on top.
floor spec: 100mm trowel finish slab on 1200 gauge polythene dpm on 100mm (min) compacted or rolled mot type 1 (30mm-dust).
Any chance of a quick diagram to show dpc
Also for 30sqm, 100mm thick, how many tonns of hardcore is required?
