DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Potterton combi 80 boiler problems
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
SMKnight
from United Kingdom
PostPosted: Wed Oct 01, 2008 3:02 pm Reply with quote
Hi, this is my first post on this forum site and I am hoping to get some advice on the following problem.
The house I bought last winter has a Potterton combi 80 boiler and worked fine.
The central heating has been turned off throughout the summer. I turned it on for the first time the other night and the following problem occured. The boiler knocked and banged a bit, possibly a bit of air in the system? but after 30 seconds steam/hot air and the odd splutter comes out of the top of the boiler and then shuts down. The system then tries to start up again but goes into 'Lockout'
After looking for any obvious problems - bleeding the radiators etc... I found there was no pressure in the system. I have re-pressurised to just above 1 bar and re-bled the radiators and started it up again but the same thing just keeps happening. I have done this about 6 or 7 times now.
The system pressure does not change much when the steam is being released, it just stays around 1 bar.
Any thoughts are appreciated as my plumbing knowledge is minimal.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 815 times
PostPosted: Wed Oct 01, 2008 5:00 pm Reply with quote
Check that the pump has not stuck.
See FAQ's on how to do this.
Back to top
 Alert Moderators
dangermouse46
from United Kingdom
Thanked: 3492 times
PostPosted: Wed Oct 01, 2008 5:14 pm Reply with quote
those cp pumps have a black hexagonal vent cap. twist anticlockise and pull out. . . . .
Back to top
 Alert Moderators
Soggy_weetabix
from United Kingdom
Thanked: 1 time
PostPosted: Wed Oct 01, 2008 7:08 pm Reply with quote
If your pump is ok the next culprit will be the wax divertor valve.
Not too easy for a DIYer but you can be guided through by the service engineers who repair them frequently.
David
Back to top
 Alert Moderators
SMKnight
from United Kingdom
PostPosted: Sat Oct 04, 2008 8:00 pm Reply with quote
Thanks for replying.
I have opened the boiler up this afternoon but problem not solved.
Gonna get an engineer round.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3612 times
PostPosted: Sat Oct 04, 2008 11:31 pm Reply with quote
David
If the pump is working properly and the boiler is not blocked then it would control itself perfectly if the wax capsule if faulty.
I would first measure the max/min gas valve pressures and then measure the resistance of thentemperature sensors.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potterton Combi Boiler Problems 2 600 Tue Oct 14, 2008 3:07 pm
Potterton Combi 80 mains problems 8 920 Wed Feb 21, 2007 7:59 am
potterton combi 80 problems! 4 80 Fri Feb 18, 2011 10:00 am
potterton combi 100, problems since draining system 3 3700 Sun Sep 12, 2004 10:55 am
Potterton combi problems 2 320 Fri Sep 09, 2005 2:10 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
