Excessive wear on masonry bits.
2 Mar 2007
Good evening everybody.
I have tried to drill a 6.5 mm hole in a 18 x 9 x 4.5 block in an outside garden wall to fit rawlplugs.
I was using a rotary impact hammer drill fitted with a 6.5 mm masonry bit.
The bit is manufactured by Pro Drill.
Having drilled two holes I found that the tip on the bit was totally worn away. I then used another similar bit and in this case the tip was worn away before I had succeeded in drilling the hole.
Perhaps I am using an incorrect bit. The cost of the bit in UK currency was approximately £1.50.
Could someone please give me some advice!
Many thanks
Spend a few quid more and get a decent bit!
I would say somewhere around the £5 mark should get you a fairly good one.
For a regular hammer drill I'd suggest the Dewalt Extreme 2 bits. They have served me well. Although I tend to use the SDS on anything that puts up any sort of resistance now :LOL:
@ <neo> and neds
Many thanks for your advice.
Much appreciated
I've used cheapies no problem. And they last for many holes not just one or two
The thing to do is use a slow speed, and don't press on hard - let the drill do the work
My experience has been the same as Woody's. I use the same technique too and have never had a problem.
