DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Combi in Loft space
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
JonB
from United Kingdom
Thanked: 6 times
PostPosted: Sun Oct 05, 2008 9:15 am    Post Subject:
Combi in Loft space
Reply with quote Thanks
My neighbour is having his 1940's semi refurbished. He is considering having a Combi in the loft and using the existing chimney stack for the flu. Is this feasible & where do you run the condensate drain.
JonB
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Sun Oct 05, 2008 9:25 am    Post Subject:
Very few boilers will be able to have flue system that uses existing chimney and then they will be very expensive , very simple to take flue out through tiles.
Condensate can be run into the guttering
Back to top
 Alert Moderators
JonB
from United Kingdom
Thanked: 6 times
PostPosted: Sun Oct 05, 2008 9:34 am    Post Subject:
Back to top
 Alert Moderators
giblets
from United Kingdom
Thanked: 5 times
PostPosted: Sun Oct 05, 2008 10:49 am    Post Subject:
Are you sure of that? Thought that condensate had to go into soil drain.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Sun Oct 05, 2008 11:00 am    Post Subject:
Its a little questionable but if the house is on a single combined soil and storm drain then its probably OK if the rainwater system is in plastic.
A 1940s house would usually be on a single drainage system but that cannot be assumed!
Tony
__________________
ARGI Registered Engineer
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Oct 05, 2008 11:01 am    Post Subject:
I've done this several times where no other option exists. It will be well diluted down.
As long as the end doesn't rest in the water in the gutter to freeze there will be no problems.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Sun Oct 05, 2008 11:28 am    Post Subject:
Giblets no it does not have to be soil drain but as agile has said it cannot go into a solely rainwater system,
But if that was the case then a condesafe could be used which neutralizes the condensate and cost £20
Back to top
 Alert Moderators
JonB
from United Kingdom
Thanked: 6 times
PostPosted: Sun Oct 05, 2008 2:23 pm    Post Subject:
It is a single drainage system.
JonB
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Gas Condensing Combi in loft space 4 380 Thu Nov 09, 2006 5:50 pm
Boilers in loft space 7 260 Mon Nov 17, 2008 6:18 pm
Cylinder primaries in loft space 6 280 Fri Apr 11, 2008 6:41 pm
woodburner flue through loft space 2 260 Fri Sep 11, 2009 10:51 am
anyone used smiths space saver plinth heaters? 5 1840 Thu Nov 16, 2006 6:31 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
