sourcing a shallow CU
I doubt you will get anything that short - an MCB itself is about 90mm. Think the shortest CUs I have seen are about 200mm
Do you mean height or depth?
You asked about a shallow CU which would indicate depth....?
You could go for a flush CU (sits in the wall).
what do you need in this CU?
according to TLC a 4 way wylex standard is 155mm high, the 2 way is even shorter.
modern din rail mount CUs unfortunately tend to be much taller.
