DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing hearth tiles
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
julesg007
from United Kingdom
PostPosted: Wed Oct 08, 2008 12:57 pm Reply with quote
I need to replace the hearth tiles of a Victorian fireplace as they have all cracked and many are missing.
If I use tiles, are there specific tiles and adhesive that need to be used - thinking about the high temperature that will be generated in use.
I was considering just using a piece of marble/slate/limestone or similar, again what would the best adhesive be?
If there is anything else that would be useful I would be grateful for any advice.
Thanks for all your help
Jules
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 158 times
PostPosted: Sat Oct 11, 2008 3:10 pm Reply with quote
I have a marble hearth that went in about 15 years ago. A stonemason friend of mine told me at the time that it would would crack but I went ahead and fitted it, partly because I liked it and partly because I got it for free. The fireplace is in the dining room so it was only intended for occasional use but wife liked it and used it a lot so it did crack.
I've just had another fireplace in the house re-tiled. I'm not sure what adhesive the tiler used as I wasn't in when he did it but it I don't think he used special adhesive as he said he doesn't usually do fireplaces, but it seems to be ok. HTH.
Back to top
 Alert Moderators
Symptoms
from United Kingdom
Thanked: 50 times
PostPosted: Sat Oct 11, 2008 3:39 pm Reply with quote
jules - the cracked tiles were more likely damaged by dropped fire tools, pokers, tongs, etc. than by heat. These tiles would have been originally set in a mortar bed (maybe even a sand/cement mortar as opposed to a lime mix); this will have become friable/loose or the adhesion has failed, hence the missing tiles. Clean off the old tiles & mortar bed down to the concrete pad. I'd re-tile using salvaged originals from a reclamation yard or as a fall-back, repros (yuk!!). Fix with sand/cement mortar mix or use a proprietary cement-based tile adhesive.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Replacing a slate hearth 6 1940 Mon Feb 02, 2009 6:17 pm
Restore hearth tiles 3 160 Sun Jan 02, 2011 11:59 pm
Hearth problem 7 220 Mon Jan 03, 2011 10:14 pm
Cleaning a slate hearth 2 280 Thu Mar 10, 2011 8:49 pm
Repairing floor after hearth removal 3 80 Fri Oct 07, 2011 1:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
