mould on window sealant
17 Mar 2007
Southampton
Hi.
The sealant on most of my windows has mould growing on them. What's the best way to remove and then replace this?
Thanks.
You can clean it off with a fungicide, but it will most likely come back
This occurs when a silicone has been used which has no mould inhibitors, and the spores actually feed off it.
It may be best to remove it and use a sanitary grade silicone or a polysulphide mastic
Most of it will come off with a stanley blade and some quick rubbing with your finder or a dry cloth.
"Silicone eater" from screwfix will do the stubborn bits
But is it just the sealant or do you have water ponding on the cill or on the frame/glass edge too? Are you wiping any condensation up and using air vents etc
If its a wider condensation issue, then try and sort that, and the mould may not take on the silicone so you won't have to renew it
Hi. there are water condensing on the rubber between the glass and pvc but as far as i know, there are no moulds growing on it. Although the rubber is dark in colour so i might be mistaken.
There are no moulds on the cill. I'm not sure if there are air vents but it's not draughtproof so i think it's ventilated.
