Hello
I am planning on building a small concrete garage.
What type of roof would you recommend I build? Was thinking about bitumen corrugated sheets - Do you need to apply anything to these sheets to seal them together), or are they just fitted dry (overlapping) with pins and thats that? Do these also work well with insulation on the inside of panel too?
Going to be using timber for the roof support as the roof panels will be angled, what could I use inbetween roof panel and block wall? I was thinking shiplap, or perhaps small bricks, but with bricks there will be steps at the roof declines. Any ideas about that would be nice.
About the floor/base: I have slabbed down (dry/cement mix) the area for an intended wooden shed base, but now I have changed my mind on a wooden one.
Once the blocks are up (the walls), should I carry on slabbing down the patio stones all the way around, then put down a layer of sand, spread the DPM, pour in the cement 2 inches thick? would this be good enough to stop damp etc?
Any help, thank you
Any help, thank you
