DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Sealing damp walls with pva before rendering
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
Author Message
qubit
from United Kingdom
PostPosted: Mon Oct 13, 2008 5:10 pm Reply with quote
Hello I have previously had loadsa problems with dumb builders browning over removed chimney patches (on the internal side of an outside wall icon_eek.gif ) and using the same black soot soaked crappy bricks which draw in like mad any rainwater and moisture from outside and makes big patches since they used a gypsum based plaster and not sand cement.
Anyway now there's one chimney left which I intend to do myself (I've bricked it up using only bricks with no trace of soot or carbon) and plan to use 2 coats of 3:1 sharp sand cement with waterproof (rendamix) I am hoping this will be enough to stop any hygroscopic salt problems
As an extra measure should I coat all the brickwork with a water/pva mix will that "seal the brickwork" in any way, normally I would just damp bricks with water before applying render
Also between coats and before the final finish plaster coat should I pva the coats or just damp down with water?
Oh and next time as an extra precaution could I paint some bitumen paint on the internal layer of the external layer bricks (solid cavity wall) to restrict any moisture coming into the internal brickwork has anyone else done this?
Back to top
 Alert Moderators
bikerm4
from United Kingdom
Thanked: 3 times
PostPosted: Tue Oct 14, 2008 10:16 am Reply with quote
Think your first mistake is calling builders dumb. You then decide you can do it better and from your post its clear you havent a clue what to do. Also please explain what a "solid cavity wall " is.
Reading your previous posts it seems your more than likely the "dumb" one.
Good luck in your projects, looks like you'l lneed it.
Back to top
 Alert Moderators
kingandy2nd
from United Kingdom
Thanked: 49 times
PostPosted: Tue Oct 14, 2008 1:17 pm Reply with quote
A bit harsh there bikerm4, but biker’s right… there’s no need to insult your builders.
In answer to the title of your posting, PVA won’t seal a damp wall. If it is damp, it's best to rectify the source of the damp before rendering or plastering.
Back to top
 Alert Moderators
qubit
from United Kingdom
PostPosted: Mon Oct 20, 2008 1:09 pm Reply with quote
Thanks for the replies Mr bikerm4 and Mr kingandy2nd
Well bike if you had been left with these problems of massive damp patches on 3 of your walls left by builders who supposedly had experience in these matters and were paid a lot of money then when asked about it blamed everything else but their work (like leaking roof, chimney, etc) even though I have actually removed the chimneys totally and had everything checked by a roofing expert and still have the same problem then I think you would be tempted to call them dumb easy to judge from a distance eh
Thank you for your informative reply Mr Andy that's what I needed to know
I don't come onto this forum for human relations lessons I just need certain information, timewasters like bike don't give any useful information just insults what a clown
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Mon Oct 20, 2008 5:44 pm Reply with quote
use an s.b.r. and cement slurry to hold back any sooted bricks or salt saturated bricks.
Back to top
 Alert Moderators
qubit
from United Kingdom
PostPosted: Mon Oct 20, 2008 6:00 pm Reply with quote
Thank you Mr nose for your reply is it okay if I use cement/water slurry painted on?
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1326 times
PostPosted: Mon Oct 20, 2008 6:38 pm Reply with quote
no, as it could end up to brittle and may still bleed.
Back to top
 Alert Moderators
qubit
from United Kingdom
PostPosted: Mon Oct 20, 2008 8:01 pm Reply with quote
Okay than icon_biggrin.gif k you Mr Nose very helpful
Back to top
 Alert Moderators
helen45
from United Kingdom
PostPosted: Fri Oct 24, 2008 8:12 pm Reply with quote
I am sorry to say if you've seen what the builders done to my property you would do more than just insults.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
Interior stone wall needs cleaning and sealing 2 280 Sat Dec 31, 2011 10:12 am
dot and dab wall sealing 2 140 Tue Aug 09, 2011 9:02 pm
Sealing Plasterboard 2 180 Thu Nov 01, 2012 3:55 pm
Sealing drywall before wallpapering 2 80 Wed Nov 07, 2012 8:53 am
Sealing a hole in the bathroom wall 2 140 Sat Nov 29, 2014 5:47 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
