PIR WITH INTEGRAL COLOUR CAMERA
5 Mar 2008
Antrim
Have any of you real pro's installed an alarm system that uses ACTIV8 COLOUR: SINGLE CHANNEL QUAD PIR WITH INTEGRAL COLOUR PINHOLE CAMERA!
Just wondering how they are installed and how they work?
Sounds like the ultimate alarm system :eek:
why do you want it?
its a PIR with a camera in it
better picture / result with a pir and a separate camera
They are not a alarm system.
Its just a PIR with a small camera and mic in it.
The pir is wired as a normal PIR to a normal alarm system, and the camera / mic goes to your cctv recording setup.
Or you wire the PIR to your cctv setup as well if it has inputs.
You would be better of with a seperate pir and camera for best results.
Pinhole cams are not exactly going to give you that good a result.
Its not that good a pir either
If you are that interested try a search for "covert cameras", you will find pinhole cameras in all sorts of things. the reason its in a pir in this case is nothing to do with the alarm, its some where to hide the camera.
