I have recently had a Tower actuator installed (with new valve also) and ended up having to finish the job myself!! The concern I have is that mains power is removed and switched back on, the actuator sits in its de-energised position and remains cold (as I would expect). When either heating/water/both switch on, actuator activates. All good. However, when both switch off, I would expect the actuator to return to a de-energised state. It doesn't but instead appears to hold its final position and the body gets hot and stays hot. Remove the power and it returns to de-energised state.
It replaced an old Switchmaster motorised valve and I am not sure this is an appropriate replacement. I have a Switchmaster 900 timer (clockwork!).
Should the actuator de-energise when water/heating off and so return to an 'off' state? If not why does it get so hot?
Any help appreciated!!
